redhededgreg
Member
The facts: 09 RT, 35K miles. Never a blip-always perfect, that is, until...
I'm 2000 miles from home riding across the upper peninsula of Michigan, commonly known as the UP.
Just crossed the border at 'The Sue' and filled up near empty tank with Shell V Power on the US side to avoid the nearly $6 per gallon Canada charge. Same station I had filled at about 10 days earlier when I was headed east.
After filling and heading across the UP, I stopped for a break after about 100 miles. After 20 minutes or so, saddled up and bike turned over but would not start with repeated attempts. Traveling with GS 911 so hook it up and no fault codes show. Thinking, maybe bad fuel. I get and add some SeaFoam, slosh around in the tank and try again. After several more tries, engine finally catches but running very roughly, on obviously one cylinder. Stop and restart and nursing the throttle, eventually smooths out. I hop on and continue west running at 4500-5000 rpm the next 80 miles to try to get as much fuel burned as possible.
I get to next town for overnight stop and immediately fuel up (about 3 gallons worth) with ethanol free premium. Bike starts up fine after refuel and again after i register at motel and move to room. Next morning...no joy. Bike will not start. Tried applying throttle, tried to the point of weakening battery and getting a jump for more tries. Would not fire or even hint at catching. Try repeatedly at 20 minute intervals.
Roadside assistance gets me to nearest dealer (not near). Get bike off truck and after explaining behaviour and problems, showing tech how bike will not start, of course!!!!!, it starts-not as it should, but it does start.
They keep to check the next day and after synching TB's and checking for any pinched fuel lines etc, give the bike a clean bill of health and send me on my way the next day. I plan my route west so my next stop will be near a dealer in case bike doesn't start the next morning. Bike starts the next morning and the morning after and the morning after that, but it's not quite right. After enough miles, we become very sensitve to subtle and not so subtle changes in our bikes' behaviours, and i can sense something is off. I sense this in the way my bike is running at start up and how quickly it starts-all is not as it should be.
On my final day, a long day, i take one last break before making the final 100 miles home. Done with break, ready to ride on...bike won't start. Turns over but gives not the slightest hint of catching. Multiple tries, including with some throttle applied.
WTF is going on? I've ruled out bad fuel as I've been through multiple tanks and brands of fuel since the first incident. I think the SeaFoam added and subsequent start were coincidental.
Related information: Before the first starting issue, I rode through heavy rains for 2 days and rode through significant rain each of the remaining days as well. Looking at other posts, when i eventually got home (via roadside assistance) i immediately looked to the FPC as a possible cause. No sign of any moisture there and no corrosion on contacts. It appears fine.
I hooked up the GS 911 again and no fault codes are present.
I'm at a loss so far. Please don't suggest any causal relationship between side stand versus center stand parking. It's never been an issue before with this bike so i don't much believe it's a possibility this time. Besides, the last time i was stranded, close to home, i had been riding about 200 miles straight beforfe stopping, and i did put the bike on the center stand when i took a break before it refused to start.
There are some very knowledgeable sources of information on this forum-i don't pretend to be one of them, but i would appreciate any suggestions for trouble shooting offered. I definitely have a specific and serious issue at this point. I hope my reluctance and hesitance to turn it over to a dealer again is understandable.
