Reverse Lowering?
jreicker
I have an opportunity to purchase a 2019 F750GS at a reasonable price. But it is factory lowered. For touring I would feel more comfortable with the standard height. Is it possible to reverse the lowering?
I'm sure it would be possible to reverse the lowering by replacing the parts that are different between the standard and the low version. Someone else may have a bit more info on exactly which parts are different, but for example I know that the rear shock is different. I believe there is some difference in the front forks (shorter springs?).
Something to keep in mind would be that you could probably buy a regular-height shock that someone else has removed, but if their bike has the ESA feature, I'm not sure how that would work with the non-ESA bike.
The other question would be the seat; I would assume that the bike came with the factory low seat. There you would have the simple option of trying to find a take-off seat from someone, or just go to an aftermarket seat (for example Sargent).
Every now and then there are posts on the F bike sub-forum of ADVRIDER (Parallel Universe) by someone wanting to trade parts to raise or lower a bike. Post there and on https://www.f800riders.org/forums/ and you may get lucky. I know that the F700GS lowered has different forks, shock, side stand and center stand than the standard version. Easy to check for the F750 by looking at a parts fiche to see if BMW lists different part numbers for the two versions.
Parts fiche tip was very helpful. Thanks.
