Replacing front turn signal (LED) R1200RT
kevinsclo
Can someone shed lights on the proper steps to replace the front LED turn signal unit?
I pull out the speaker and while I could see the 2 screws holding the turn signal light assembly, but I can’t figure out how to access the 2 screws.
Thought I would check here before I try to remove more Tupperware than I have to.
Tapatalk
Here's the procedure from the BMW RSD Manual
If you need details on any of the Preparatory work I can expand these sections and send post them
Hope this helps
