T
TURK
1973 R75/5 w/ bing 64/32/9 & 10.
When I try to adj idle on the carbs, one at a time to 1000 rpm per Clymers.(pull opposite plug wire and ground extra spark plug ,adj idle to 1000 rpm leaving spark plug in head.)
I put both wires back on and the idle rpm goes to 2500.
This happened before I rebuilt the carbs.
I rebuilt carbs,happens with pulled off throttle cables and cables back on,checked choke position.
Adjusted idle air mix,readjust idle back and forth.
I did this after my first ride 20 miles after rebuild and the bike ran great,smooth all rpm ranges!!
Used fans to cool bike while idling.
valves adj.,timing done.
What am I doing wrong?
Thanks.....Al
Thanks.....Al
