kentuvman
I'm either getting close or running out of bullets.
This morning, I jumped all the wires that go on the ignition switch and still just a "click" from the headlight relay.
I removed the handlebar housing and the only suspect I see is a bunch of dust balls on the turn signal switch. Will blow out with compressed air later today and spray some contact cleaner. Still, don't think that's the culprit.
It's gotta be something real simple.
I'll let you know when I get to the bottom of this.
Could it be a diode board issue? From what I've read I don't think that would prevent circuits from powering up before starting bike.
I also need to confirm bike is in neutral, although we have the clutch bungeed in the open position.
