R1200GS LC Preload: One helmet vs. Two Helmet Setting, some GSAs too
075038
R1200GS LC Preload: One helmet vs. Two Helmet Setting: Many differences
The list of pluses and minuses keeps getting longer:
New to me '13R1200GS LC has these Dynamic ESA "helmet settings" called rear preload also called "one up" and "two up (with luggage)". It has a stock rear shock.
After 3 months, I'm learning their effects. Please add to and debate this info and hopefully many others will learn more than in the BMW Rider's Manual.
The "two helmet setting" gives you:
More rear preload
Less sag
Proper sag for two-up riding with luggage.
New Youtube video:
https://www.youtube.com/watch?v=pxIOGTh2tu8
measured 46mm of rise between 1 helmet and 2 helmet settings.
A steeper head angle which makes turning in easier, a ~ 46mm rise in back over a 1507mm wheelbase is ~1.75 degrees steeper. Nominal is 64.5 degrees.
The rear shock that is not Dynamic ESA takes 30 turns to cover the range.
you may also find that you want longer legs at stops to use this setting as the seat will be about 1.8 inches higher.
More ground clearance, handy on some rocky or rutty trails
The R1250GS User manual suggests using this setting called "Max." Dynamic ESA fixed "for off-road use."
Less chance of bottoming out
Less chance of touching a peg while cornering.
The sidestand may appear shorter
The centerstand will be easier to lever up.
When the rear is set at max height, the seat moves more over the top of the footpegs.
The pillion and you may slide forward more easily as the rear lifts and pivots about the front contact patch. It's just 1.75 degrees but noticeable to me.
There is some slight highway front wheel wiggle.
The "one helmet setting" gives you:
Less rear preload
More sag
Proper sag for 170# rider, no farkles, no bags. Level the bike and headlight.
a more relaxed head tube angle which makes the bike like to go straight
it will have slightly less wind drag,
maybe better mileage
maybe a higher top speed.
may want to wobble less.
easier to reach the ground
The R1250GS User manual suggests using this setting called "Min." Dynamic ESA fixed "for easier dismounting."
harder to lever up onto the centerstand. Plantar Fasciitis possible with casual shoes.
less ground and peg clearance
The Vario Top Case Pillion backrest leans back some relative to the seat.
Headlights and other forward facing lights will shine further down the road.
Long days solo on highways benefit with less front wheel wiggle and a windscreen that is slightly taller.
Of course the "one helmet plus luggage setting" falls in-between, my bike seems to be closer to the two helmet setting.
The Rider's Manual barely mentions the effects this setting has, if at all even in the "Technology in Detail" section.
What is the designed sag difference with the BMW stock rear ESA shock? GS? GSA? Rally? Touratech?
Would the ride be more springy/cushy with the one helmet setting?
Does the paralever have universal joints at both ends of its shaft? If so which setting runs a straighter line, bending the U-joints less each revolution?
The intent is to level the bike when riding with a passenger. It does raise the rear end if you ride solo.
Original Poster Here: GS One Helmet or Two Helmet ESA setting effects
Many updates to the original post as information has been observed and collected.
In my experience on BMW's and other brands with ESA or similar, riders who want to feel a more sporty feel to the front end (by lifting the rear) and firmer suspension for better handling tend to go up on their preload, sometimes all the way to two up with luggage when that option is available.
I have played with the suspension settings on our '16 R1200RS and our '19 K1600GT Sport.
Note that I ride two up with bags, trunk and tank bag 99.9% of the time.
On our R12RS LC two up with bags in road mode is the right setting for us.
One up with bags in Road mode and she wallows a bit.
When put into Dynamic mode with two up and bags the suspension is so stiff it jars our teeth.
In the Dynamic mode one up with bags the suspension automatically goes into a "stiffer" mode that again is a bit too taunt for us.
The difference in seat height is about an inch between the one up with bags and the two up with bags settings.
On the other hand, one up with bags in Road mode on our K16GTS is just right.
The seat height drops about an inch or more, and the suspension gives us a taunt but pliable ride.
Putting the K16GTS into dynamic and like the R12RS it goes into a "stiffer" mode that is too much for us.
Too bad, throttle response on both bikes in Dynamic mode is definitely a hoot!
