Hi Roger,
It's #4 out of 4. Fuse 1: Instrument cluster - 4 amps
Fuse 2: Tail lights - 4 amps
Fuse 3: Instruments, horn, power socket - 15 amps
Fuse 4: Motronic, fuel pump - 15 amps
Johnny
I'll probably never have to work on it again...
Thing is, it's a beautiful machine with only 24K miles, but it's my first oilhead, and I had no idea how well it was supposed to run or what to look for or how to keep up with it. Thanks to you great folks, I'm way, way into it now. I'll probably never have to work on it again, but I'll keep in touch anyway, and thanks for everything!
Great to be here,
Johnny
Hey Jasper,
I'm not the expert on this at all, but here's how you do it: Leave the TPS in place, slide the protective sheath down a half-inch or so until you have enough room to slip a couple of sewing needles (hatpins work great) up in there next to the pins. Hook your alligator clips from your voltmeter to the pins. Now turn the ignition on (don't start the bike) and read the voltage. If it's not right (optimum is 360 mv or a little less), you adjust it by slightly loosening the two screws that secure the TPS to the throttle body and then tapping the right or left side of it lightly with a rubber hammer in order to rotate it clockwise or counterclockwise until the voltmeter says what you want it to say. The TPS is connected to the outside end of the throttle shaft and it is adjusted by rotating it. Its easy to do but a few degrees of rotation make a lot of difference, so go slowly.
Hope that makes sense; sorry I'm not a better instructor.
Johnny
Johnny's description is very good. To be clear - yes, you have to keep the cable attached to the TPS. Once you have a voltmeter hooked up you are adjusting the position of the TPS by "tapping" it, just a tiny movement will change the voltage. Personally, I think .360 is too low - I would aim for the voltage to be about .370-.375.
Well....
I measure 800 mV to start - wow right ?
I turn the TPS until I read 370 mV. It's now cranked all the way over, but reading correctly so I leave it.
Pull the fuse and twiddle my thumbs for 10 minutes. Then replace the fuse, cycle the throttle three times.
Start the bike....no way, it's not able to hold an idle. wtf?
Check the voltage again and it's 71 mV !!??! wtf?
I adjust the TPS again to 370 mV, and it's more in the middle of the adjustment range.
Start the bike, runs nice, idles a bit high maybe.
Take it for a ride, it for sure wants to idle high (like 1300), so I turn in the two BBS a bit, and I think it's good but by now it's all hot and bothered, so we'll have to see how it behaves tomorrow.
I think it's better though...at least it's not idling low and lumpy any more.
Jasper. It sounds as if your cables may not have been loosened properly before adjusting the TPS. Here is the BMW procedure for TB Sync: http://forums.bmwmoa.org/showthread...nd-Zero-Zero&p=1003851&viewfull=1#post1003851. When the cables are correctly loosened the TPS will remain stable unless your TB shafts are badly worn. If they are, with the cables loose, adjust the TPS with the engine idling, then the engine vacuum will fully close the butterfly.
