Ya see, right there, that opening, ya lost me right there
So my plan worked...
BTW, my 2000 S doesn't have stick coils, but if it did they would definitely be suspect.
Thanks again,
Johnny
Johnny, When you get to syncing your throttle bodies, have a read through this: BMW Repair Manual Throttle Body Synchroization Procedure.
It's fairly detailed but will produce good balance and correct cable tension. Roger
All I have to do to make this go away is to either put in the clutch or use the throttle to increase the engine speed to 1000 or so RPMs, which is where it should be idling anyway. I don't think this clanking is related to the too-slow idle. (Could be wrong - whaddya think?) Plus I love the way I can make it disappear when I want to.
I don't follow you. If squeezing the clutch is one way to make the idle return to normal, and the clanking goes away, it sounds like they are very related. Am I misunderstanding your description?
Quick tip, just between me and you, watch out for that BC1100S guy.
If you've set the valves to "factory spec", then they'll be tight when they are hot, and this will most definitely be detrimental to a steady idle. Intake spec is .006", so I always set mine to the sloppy side of .007". Exhaust spec is .012", so I set mine to .014". A bit noisier, but it works GREAT.
Low idle will seem to exacerbate clanking... but it's also worthwhile to upgrade your left-side cam chain tensioner to the newer type.
Thanks Paul,
I went out yesterday and put another 60 miles on the bike and I'm seeing steady improvement. I'm still in that tankful of new fuel laced with F.I. cleaner, but I plan to finish that off later today and then refill with somewhat less cleaner added.
After my ride yesterday I re-synced the carbs and now have a setting of 1.5 on the right BBS and 2 on the left at 1100 rpms. It idles with no assist from me at 1000 but it just barely holds that engine speed and you keep wanting to run it up a little. However, it doesn't die instantly at stop lights anymore, so I'm calling that an improvement. Hopefully some more riding and conditioned fuel will contiinue to clear it up.
I could probably quick-fix it by adjusting the throttle plate stop, but it still has the factory blue paint in place so I'm holding off on that for the time being. The o-rings on the BBSs appear to be in good shape, but I'll take a closer look at them with my old people's magnifying glass today.
By the way, while I had the left carb off I went ahead and replaced the original cam chain tensioner with the new and improved version (Thanks, Rusty@Max BMW) and it made a huge difference in the engine noise at idle - Huge! Now the only outstanding noise is a little clatter from the right throttle shaft at idle. I'll put that on my to-do list.
Cheers,
Johnny
