Are you talking about the top fork filler plugs that hold the stanchions against the top bracket? If so, the stanchions would still be clamped in the lower bracket. Would they be loose enough to make a difference?
I just redid the front end on my '78 R100S. I can not reinstall the front fork brace. It is the two-piece tubular steel one that mounts together with the four fender mounting bolts over the stamped steel fender base. The bolts just don't line up.
...The brace parts do not line up with the fender.
As you know, the fender is mounted on the sheet metal support and the braces connect to the same bolts that the fender is mounted to the support.
There is about half to 3/4 inch space now between fender surface and brace mounting eye.
Rotating hoops:
Apparently this was a problem worth addressing, as both Luftmeister and CC Products
later offered braces with the hoops welded together with plates at each side,
and the 2-piece was discontinued.
By that time, I was a dedicated Telefix fan ...
Wait a minute....
If everything was finebefore, then you simply have to go back and figuer out what yo've changed to screw things up. OTOH, iy youre fitting the brace to a different bike, all bets are off!
"But...A local airhead guy I consulted on the problem told me that the hoop brace was always intended to be used INSTEAD of the stock sheet metal under-fender brace NOT TOGETHER WITH IT. That's the reason it has the mounting eyes for the fender, which are actually otherwise totally useless. Anybody remembers and concurs?"
I believe that many who used the hoop-braces at the time simply discarded the stock sheet-metal piece.
...Although both braces mount-sort of- in the same space, they do not interfere with each other and it seems like they COULD be mounted together...
