Hi all,
I need to replace the fork boots / gators. I'm looking for the easiest path - from the top or from the bottom. In reviewing the manual, both paths seem quite involved.
From the top, it seems I have to remove the dampener knob, ignition, handlebars, turn signal repeater (haven't located that yet)... I assume to have enough clearance to remove the top nut. I can get purchase on it and loosen, but I suspect based on the pics it's too deep to clear everything and come all the way out.
From the bottom, it seems I'd potentially have to replace the seal, and apparently requires special tools to install and to get the slider back on the post (none of which I have). I don't want to go that path and get stuck for a week waiting for parts.
The seal is not leaking and the forks are otherwise fine and operational, and so I have no interest in going places I don't have to go. Is the manual being overly cautious? Is there a trick to do this easier and avoid a waterfall of parts, tools, and work?
