R100R crash bar removal
Welcome to the forum! I'm assuming you don't have the Mystic model. I can see from the fiche that the sidestand makes use of the safety bars. It would appear that you could convert to the Mystic sidestand configuration:
http://www.realoem.com/bmw/enUS/sho...994-2473-BMW-R_100_R_Mystik_94&diagId=46_0294
The engine mount bolt may not be long enough. Snowbum lists two bolts, one 315 and one 327 mm long...maybe you might need the longer one?
http://bmwmotorcycletech.info/hardware.htm
It would be good for you to see a Mystic and make some comparisons.
