happy wanderer
Day Dreaming ...
So, you do have the right amount of fuel in each float bowl? Should be something a little over 1" in height in the bowl.
As for the intake spigots, there was a write up by Oak in the latest Airmail. His method for removing them is to take the heads off and use an oven to heat the head to 350 degF. Then you stuff a cold, wet sponge into the spigot and use a pipe wrench to remove the spigot. Installation involves using blue Loctite and Hylomar with the spigot being cooled in the freezer. Then reheat the head in the oven and when at temp, quickly put the spigot in place.
Snowbum has a slightly different approach...looks like his way leaves the head on the bike...near bottom of this page:
http://bmwmotorcycletech.info/break-in.htm
I thought the spec for fuel depth in the middle of the bowl was 20mm to 24mm.
1 inch is 25.4mm so that might be too high?
