s_alt
Hey guys,
Got an R100T 81' Bike has been running a little on the leaner side and was recommended to put a little larger needle jet in. went from 2.66 to 2.68. bike is definitely not running as lean anymore. checked the sparks after a little ride and they looked much better. Not wet or black and not white. This morning as I was riding though I tried really opening my throttle was going around 70ish mph and my bike just stalled. I was able to start the bike back up again but now its not wanting to start again whereas as it happened again. Im curious if it got too much fuel? or maybe not enough? should I maybe go a little larger on the Main jet? Im curious if its running leaner on the idle jet but might of been running fine before with the 2.66 idle jet? I unfortunately don't have a socket with me here at work so I cant check to see the plugs to see how they are looking.
I check the tank to see if the vent hole is plugged but it seems clear.
Needles are positioned on notch 2. rest of the measurements are 165(main jet) -2.68(needle jet) -50(idle jet)
I put on a different straight pipe exhaust as to why the bigger numbers.
I just replaced the coils and has a newer charging system all is working well on the electrical side I would think. Just replaced the spark plugs with the proper gapping.
Any insight is much appreciated.
Thank you
Thank you
