Oilhead Sight Glass
Paul_F
RK Ryder
It was mentioned in a recent post the newer sight windows for Oilheads are now glass rather than plastic. Does anyone know when the switch was made from plastic to glass? Curious as mine was last replaced in 2009.
I can't answer the specific date question but will offer that if I were to believe certain absolutely certain statements in that thread I would be forced to conclude that my pencil-type soldering iron melts glass. Or, maybe a person could get cut on a shard of broken plastic. Take your pick.
There has been some supersession on part numbers for the sight glass. This is what RealOEM shows now:
11 11 8 523 906
Oil-level check
Supersedes:
11118527546 (08/01/2010 — 07/19/2011),
Exchangeable retrospectively11117710474 (03/01/2008 — 11/15/2010),
Exchangeable retrospectively11117703823 (03/01/2007 — 03/14/2008),
Exchangeable retrospectively11117661648 (05/29/2000 — 04/19/2007),
Exchangeable retrospectively11111465293 (06/01/1998 — 07/26/2000),
Exchangeable retrospectively11111460774 (08/01/1983 — 08/07/1998)
Part 11118523906 was found on the following vehicles:
K25 (R 1200 GS)   (12/2002 — 12/2012)
K25 (R 1200 GS Adventure)   (03/2005 — 07/2013)
K25 (HP)   (08/2004 — 11/2008)
K26 (R 900 RT, R 1200 RT)   (11/2003 — 06/2014)
K27 (R 1200 R)   (11/2005 — 07/2014)
K28 (R 1200 ST)   (05/2003 — 11/2007)
K29 (R 1200 S, HP2 Sport)   (11/2004 — 07/2010)
K21 (R nineT)   (01/2013 — 12/2019)
K22 (R nineT Pure)   (12/2015 — 12/2019)
K23 (R nineT Scrambler)   (09/2015 — 12/2019)
K32 (R nineT Racer)   (12/2015 — 07/2019)
K33 (R nineT Urban G/S)   (03/2016 — 12/2019)
K42 (HP4)   (09/2011 — 07/2014)
K46 (S 1000 RR)   (09/2008 — 11/2018)
K47 (S 1000 R)   (02/2013 — 12/2019)
K49 (S 1000 XR)   (05/2014 — 11/2019)
K67 (S 1000 RR)   (02/2018 — 12/2019)
K69 (S 1000 XR)   (12/2018 — 11/2019)
R13 (F 650 GS, GS Dakar)   (02/1999 — 10/2007)
259 (R 850 GS, R 1100 GS)   (04/1993 — 07/2006)
R21 (R 1150 GS)   (09/1998 — 11/2003)
R21 (R 1150 GS Adventure)   (07/2001 — 09/2005)
259R (R 850 R, R 1100 R)   (09/1993 — 11/2002)
R28 (R 850 R, R 1150 R, Rockster)   (11/1999 — 07/2007)
259 (R 850 RT, R 1100 RT)   (05/1994 — 11/2001)
R22 (R 850 RT, R 1150 RT, R 1150 RS)   (01/2000 — 03/2006)
259 (R 1100 S, R 1100 RS)   (01/1992 — 07/2005)
259C (R 850 C, R 1200 C)   (04/1996 — 07/2004)
259C (R 1200 C Montauk)   (10/2002 — 10/2004)
259C (R 1200 C Independent)   (05/2000 — 08/2004)
K30 (R1200 CL)   (10/2001 — 07/2004)
K589 (K1, K 100 RS)   (08/1988 — 09/1993)
K589 (K 1100 RS, K 1100 LT)   (06/1989 — 04/1999)
K589 (K 1200 RS, K 1200 LT)   (04/1996 — 07/2008)
K41 (K 1200 GT, K 1200 RS)   (03/2000 — 07/2005)
K589 (K100, RS, RT, LT)   (05/1982 — 10/1991)
K569 (K 75, K 75 C, K 75 S, K 75 RT)   (12/1984 — 06/2005)
A61   (01/1997 — 01/2000)
A67   (06/2005 — 09/2005)
Best,
DeVern
I can't find a photo to prove this, but I believe that the older plastic sight glass had a dot in the center. The new glass windows only have a circle on the outer edge.
Maybe someone with an original Oilhead sight window can verify.
My original plastic version had a red dot in the center. The new glass version does not.
11 11 8 523 906
Oil-level check
Supersedes:
Best,
DeVern
Wow! That's a lot information; thanks!
Mine has no red dot so it must be glass.
Thank you!
