nevada72
Vintage User
Edit - File this one under the "never mind" category. I was looking at the wrong light. ![hungover :hungover :hungover](https://forums.bmwmoa.org/images/smilies/hungover.gif)
I have a recently acquired a "ran when parked 3 years ago" 1983 R100RT. The bike looks fairly unmolested with no obvious buffoonery so often found on bikes of this vintage - i.e. everything looks oem. I did the basics to do a first start to evaluate - fresh gas, check carb bowls to gauge neglect (they were dry), check oil (it's so-so), new plugs, new air filter (old one looked like it was 100 years old), charged battery. It turns over fine, but the right carb leaks like a sieve (replaced bowl gasket - no help). Guessing the float doesn't, among other things. But even so, I figured it would at least start with a full bowl and the gas shut off. Not so much. It gets spark, it's getting air, so I figure carbs need to be rebuilt.
But that's not my primary concern. In reading up on the oil change situation, I learned of the oil cooler/filter change nightmare. Somewhere along the line I read when changing the oil and filter one should crank the motor with the plugs out/gas off in order to pump oil into the filter. I thought I read that after cranking a short while the oil light is supposed to go off. Mine doesn't. Is this a problem?
Btw - this is not my 1st post. I originally joined in 2008. My membership expired and I didn't renew until recently. I guess my old posts and count have evaporated.
