Odometer Quit
gfdunn
my 84 RT odometer quit after i filled up and reset the trip set. Speed still registers so the cable is still cranking. I guess the odo & trip have cratered. Can these be fixed or do you have to replace the whole thing.
Thanks for any experience.
Gary.::p
Fix it...
They can be fixed. I would check the Airhead website and do a google search. If you are not comfortable fixing it yourself, I know that Palto Alto in California fixes them, as well as Re-cycle in Ohio. They will check it first, call you with a price and then you go from there...
I suggest that you take it off the bike, lay a towel down with good lighting and to start taking it apart. It may be something simple. They are also know for requiring a little lubrication... :thumb
Gary.::p
Gary;
My 84 RS did the same thing. Check this link on the Airheads site for a fix if you wish to try it yourself. http://www.airheads.org/content/view/160/98/
I read/printed this article and used a bit of JB Weld to do the repair. Be sure and apply some high quality grease to the moving parts, clean all the electrical connections, etc., while you are in there.
You DO belong to the Airheads right????
dj
yes you can fix it yourself
follow the links above
I did mine about a year ago and it is working great
by the way, while your in there, its a good time to replace all the bulbs, their cheap and you already have everything apart anyway
