SteveAikens
Proud Veteran
No drilling required. You're trying to push the last tumbler down to remove the cylinder, not press it front or back. Look at the 9th picture down in the link provided. That tab/tumbler you see sticking up is the locking mechanism that holds the cylinder in place. Put the key in the tumbler, tehn you have to press the tumbler down from inside the hole. Takes a little fiddling but it will go and you can slide the cylinder back out. DON"T FORCE ANYTHING. Press too hard on that tumbler front the side and it will bend and you have a whole new set of problems.
You may be at that point that you need to slip over to your dealer for some help.
