Newbie here. Just got an 83 R100RS from my brother in Colorado. It appears that the pulse air system has been removed. Unfortunately, I have to have it emissions inspected/tested before I can register it in AZ so it looks like I need to put the pulse air stuff back on (they apparently look for it). I got all the bits from a guy on Ebay and I think I see how it all goes in. However, it looks like the PCV system has been modified, at least it looks different from the diagram in Clymer's and in the fiche I've seen at various places. Here's what it looks like under the air filter (a K&N that I plan to replace shortly).
The big hose that comes in thru the front of the box, which I assume comes from the PCV valve on top of the engine, is routed out thru the hole that is for one of the pulse air valves. It goes down to what looks like a canister that's mounted to the cross member in front of the rear wheel. I can't find any mention of this canister anywhere. Here's what it looks like:
It's attached to the cross member with zip ties. There's a smaller hose that runs from the canister back up to the air filter box thru a hole in rear of the box (the smaller brown hose on the lower right in the filter box pic) and connects to a tee and into each of the air intake horns. I expected to find the big hose from the PCV valve going to the tee and into the intake horns. Anyone know what that canister is and why it's there? Those hoses are using holes that I need for the PAS so I guess I'll have to put it back to the way it shows in the diagrams and remove that canister. Or is there something I don't know about?
Any info/advice/opinions will be welcomed.
Thanks... Mark
Thanks... Mark
