Need help finding this drain tube elbow connector
Blueman
The female end connected to the drain tube under the fuel tank and the male end connected to a hose that was routed behind the engine. Is this an Airhead part? Looked on the fiche but did not see it. Counting on the collective knowledge of those more informed than me! 1978 R100RS fuel tank.
Thanks in advance for your help.
I'm sure Steven will be right along! But I can't imagine that is an OEM part. My '78 R100/7 tank is not that different from the RS tank of the same year. On mine, there is only one hose that comes out of the bottom of the tank....that's all it is...a simple hose. It plugs into the outlet port which drains essentially water from the cup that is around the fill hole. The other end of the hose routes to somewhere around the swingarm and drops below to the ground.
Yep
Nothing fancy needed. Just a length of hose that fits the fitting on the bottom of the tank. Then the hose routes out to the battery box, swing arm area.
Currently on my 78RS, I don't have the hose hooked up. I lost it during a rebuild never had a problem without it.
On my 84 RT I do have it hooked up and a more then a few times after I have filled the gas tank in the summer and let the bike sit in the sun, the gas expanded and overflowed into the run off and down the hose. Better to have it go down the hose onto the ground in front of the swing arm than to flow onto of a hot engine. Why this has never happened on the RS is most likely because of fueling and not letting it sit afterwards. I need to go to the loo first then pump gas, LOL.
I have a hose that fits the fitting cut to about a half inch length, then, a smaller diameter hose plugged into that. No clamp nothing fancy. Cheers, St.
Elbow
That elbow resembles some fittings that I have in my lifetime collection of brake bleeder adapters. If you could post ID and OD dimensions I could confirm and see whether I have a spare. And as mentioned already, neither of my '78s, an R80/7 nor my '78 R100RS have such a fitting.
Cheers, Russ
auto parts
A quick pop into an Autozone or some such auto parts place with a selection of vacuum fittings, gas line fittings and such might turn up a copy.
Don't know how much stuff you have in your garage, in mine, I have bits a bobs of hose and wire squirreled away in a tool box. Hence, the hose with in a hose fix on my bike. Cheers, St.
Thanks for your offer Russ! I will try looking in some auto parts stores.
