It is time I stop riding other's threads and start my own. I have done oil changes and such,to date on the RT, I am going to do a proper maintenance on her this summer, Going to use this thread to ask my questions.
I appreciate Mister's Rodger04, awagnon,Addict,Cele0001 and Mr Wanderer over the last yr or so to answer my questions.
I am going to use the 6 page check list for the 1150 that awagnon made up.
On awagon's suggestion, I did some searching and located Ted, and his video on the R1100RT Spline lube and reassembly. We had a short email conversation, It was good to speak with him and how he is doing. DVD is on the way.
The bike is 19 yr old with 43k miles.
Here is my list of things to do this summer while she is apart.
Pull the shocks for a freshen up and new rear spring.
Spline inspection and lube.
Check seals on crankshaft, front of trans and final drive for signs of leaking and repair if needed.
Inspect paralever pivot pins and lube. Saddleman sold me a socket and allen wrench.
Inspect Starter and lube bendix.
Replace the brake hoses with the Spegliers I have, and flush .
Inspect and change the left side Cam chain tensioner which I have.
Change the Alternator belt and tension.
Check the HES and wiring.
Clean the Throttle body's (Check and change the BBS o rings) Check for shaft to body wear.
Send injectors out for a cleaning and flowing.
Service side stand.
Service Center stand.
Change fuel hoses and clamps in tank, replace strainer, Relocate filter to safe place externally.
Replace all external fuel hoses / clamps and add QD's back in.
Change oil and air filters.
Change oil, trans oil and FD oil.
Set valves, change plugs.
Sync the TBs when back running .
Add a Aux horn I have, and Add in a Aux fuse block I have.
The clutch and throttle cables. Is a simple inspect for frays / lube sufficient? Or change out due to time?
Plug wires?
What have I missed?
Dadrider.
Service side stand.
Plug wires?
What have I missed?
Dadrider.
