PGlaves
#13338
Why should these splines ever need to be re-lubed at all?
Just about every manual transmission car or truck ever made has similar splines in similar places and they never need maintenance.
Time for a design change maybe?
Excellent question that BMW has never answered. The history is interesting though. Spline lubrication was something of an afterthought in the 1970s. But in the early 1980s there started to ba a bunch of failures. BMW then advised that the splines needed to be cleaned and re-lubricated once a year or every 12,000 miles. Eventually there was speculation that there was a big bad batch of input shafts. BMW wasn't saying. If you look at BMW maintenance schedules for Oilheads, for example, you will not find clutch hub spline lubrication scheduled. But one ignores it at their peril because lots of splines have failed. There are lots of theories as to why.
Some are convinced that a lateral misalignment of the centerlines of the engine output shaft and transmission input shaft is the cause. Some see an angular misalignment as the cause. These were established as the causes of some failures on K75 and K100 bikes, when replacing the auxiliary case (bellhousing) cured the problem.
There is speculation that the power pulses from the large twin engines cause fretting corrosion when the pulses from a four, six, or eight cylinder engine would be much less.
But the bottom line is that they need to be cleaned and lubricated because if you don't do it they fail.
