I've just used a Mighty Vac for the first time. I bled the front and rear brakes on my 2003 R1150R. Things went as expected, and I carved out enough of my afternoon for a learning curve.
Most of the attachments that come with the MV didn't seem to be much use for anything, and I ended up just using the clear plastic tubes.
The MV seemed to work as expected but for the life of me, I could not completely seal the bleed-nipple/tube connection. I had a good vacuum (indicated on the gauge) but still sucked in air from around the bleed nipple. I searched the web, found mixed reviews and advice, and tried all the sealing methods... Vaseline, teflon tape, springy hose clips and a mixture of all three. However hard I tried, I still got bubbles of air from the nipple connection. I went ahead and bled the brakes anyway because the bubbles only manifested when I applied pressure with the MV... it didn't matter if the nipple was open or closed... a vacuum produced bubbles from the nipple/tube connection. The suction was pulling any air towards the MV. So I continued on, finished bleeding, closed everything down, went for a 45 minute ride in the rain and my brakes worked perfectly.
Is there anyone out there that uses the Mighty Vac that has a suggestion on keeping the air bubbles to a minimum. Or has any sage advice concerning the use of a Mighty Vac?
Thanks.
Thanks.
