ken e
Ken
Having reoccurring problems with the urine cup front brake reservoir gasket being deformed and need some advice on if "they all do that" and I just have to deal with it, or it is just my bike and repairs are needed.
Very often in the summer, the gasket is deformed down into the brake fluid. I then remove the cover, wipe DOT 4 brake fluid off gasket and cap, then reinstall. Seems to be good for a few days / weeks, then happens again. Brakes feel a bit mushy before gasket cleaning / bleeding, and much better after.
Bike is parked out in the sun at work and all the black parts get nice and warm. Have been replacing the gasket about once a year. Bleed brakes about twice a year. There are 2 small slots cast into the cap and they are open and clean. Screws are fastened down by hand using T20 torx screw driver. Have used BMW fluid, auto store fluid, currently using Amsoil DOT 3/4.
Cannot tell if there is air pressure pushing the gasket down? or if there is a vacuum sucking the gasket down?
Thanks in advance.
