Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
Gentlemen, there certainly is an o-ring required: Item #11, in the above exploded view from the BING AGENCY manual.
The Main Jet (#1), Washer (#12), Jet Stock (#10), O-ring (#11), are all fully immersed to the bottom of the Float Bowl. The O-ring prevents fuel migration to bypass the Main Jet; up the threads past the Jet Stock; around the Needle Jet and into the Atomizer chamber; enriching the metered fuel.
In the following pictures, you can see that the Jet Stock, Idle Jet and Idle Mixture Screw locations, all have counter-bores following threading to enable a smooth bore for the O-rings; the Jet Stock with annulus for the O-ring; BINGS’ #1 Overhaul Gasket Kit CV with, among other items, the O-ring quantity and locations.
