ANDYVH
By loose tail, I mean the entire tail section. I can move it up about 1/2" very easily by lifting on the tail rack. Almost seems to "pivot" up on the rear subframe tubes going to the back, which support the tail piece, tail rack, inner fender, rear seat section, etc. Nothing is missing or loose that I can tell so far. The bolts that attach the rear subframe braces to the tranny are in place and tight. The subframe doesn't move at the rear footpeg braces. But, when I hold my pinky against the junction of the footpeg brace tube to the top subframe tube, and lift, I can feel a gap open up there, which is where there should be a solid weld connection.
So the rear panels and tail piece got to come off as I suspect two broken welds back there. The rear of the bike can't drop (yet) because the top of the tube is still intact. But I suspect a crack on the bottom of the tube. Just wonder if anyone else has experienced anything like this on the 93/94 vintage R1100RS. I should also note that my bike has a homemade tail rack to mount a Givi 52L tail box.
