I would look for ED codes...
How many of you have experienced "limp Mode" when traveling at speed?
I know it's too early in this thread for humor, so only a short note - friend had same problem, solved it with two Viagra applications...no more "limp mode". Hang in there.
Thanks for the advice. I’ll add this to my service schedule, Lube is never a bad thing unless it’s between your tires and pavement.
Thus my post to look for ED codes...
If anything, limp mode is ultra conservative, so you're unlikely to do Engine damage, because limp mode is stepping in to keep you from doing any.
Common fault is the throttle position sensor, and more specifically the connector on the back of the hand grip.
I located, disconnected and re-tightened the connector and resolved the issue in less than 2 minutes.
I’ve experienced limp home mode twice now on two different bikes. My 2016 R1200RS and my 2015 R1200GS.
I had just started my ride on the RS and was only a couple of miles from home. No power. Ragged throttle that was non responsive. I made it home in 1st gear and had it towed to the dealer, since it was still in warranty. Diagnosed as a bad throttle position sensor. No reoccurrence in 2K miles since fix.
Today my GS went in to limp mode at the end of my ride. I was putting around on a dirt road in 1st gear and no throttle response. But a constant, slightly elevated RPM, not ragged like the RS. I got to the top of the hill above my house where I knew I could coast home and turned the bike off and back on. Problem went away.
I’m due for an oil change so I guess I’ll take it to the dealer if Ft Collins, about an hour away, and see if they find any fault codes.
Both bikes are low mileage, 5.5K on the RS, and 4K on the GS.
Happened to me twice today. Once at ~40MPH on a rural paved road while slowing for turn and the second time on a long down hill stretch. All the wire connections at the throttle seem fine.
I would report this "feature" to the NHTSB. In traffic it is clearly an unsafe condition.
I’m thinking a trip to the dealer is in order. I have never seen a “limp home mode” not leave an error code.
My guess a part/sensor going bad.
It happened to me after a rain delay while riding the upper portion of the Natchez Trace. Stopped for over an hour to let a heavy rain pass over, fueled up got back on the trace. After about 10 minutes it went into limp mode. I pulled over turned the bike off, looked things over and it has never missed a beat.
I contribute this and the cruise cycling on and off to the exposure of heavy to light rain. In the days and miles since this event I haven't not one issue.
2015 1200 GS
