I did last month (70mph). Turning bike Off then back on corrected check engine light; could not duplicate, hasn’t manifested since. Scary when it happened.
How many of you have experienced "limp Mode" when traveling at speed?
...Of course, I'm concerned about engine damage, but the lingering fear that "Limp Mode" may occur in a situation where you can't exit the roadway is disconcerting.
I would look for ED codes...
I know it's too early in this thread for humor, so only a short note - friend had same problem, solved it with two Viagra applications...no more "limp mode". Hang in there.
For what it’s worth... after it happened I did a little research on my Facebook groups (recently left FB permanently) but I saw on several RT pages that the cause may be the oxygen sensor or that flapper valve close to your exhaust cone, may be sticking shut. A lot of RT owners had pictures of that component spring hinges being lubricated with some WD-40 or similar spray lube and fixing the problem. Hope this helps, as it was very disconcerting for me. Had the cruise control set, manifested itself with an immediate loss of power with lack of throttle response. Had to find a median on the left to pull into as there was no shoulder on the right.
I read about this as well. Decided to clean and lube the flapper, spring and cable (at the motor) at every final drive/spline service. I'm using a copper anti-seize spray rated for up to 1500 deg. F. Pipe is already off at that time and its easy to do.
Lube is never a bad thing unless it’s between your tires and pavement.
Or hypothetically, between the brake pads and disks, or shoes and drum as the case may be.
