BMW Triumphant
Ed Kilner #176066
Thank you for the advice I do appreciate it.
These also have a control board in them.
The literature says 9-36V DC.
I did e-mail them and got a response that while others make a dimmer for their product they do not know about the ezCAN. They advised that since it is a unknown to them it may put a load on the circuit that they are not aware of, and lessen the lifespan.
Really no help.
Since I Think I know what to ask now, I will email back and ask if the board can handle pulse modulated DC? Is that correct?
Again thank you for the help and advice.
I am really not to concerned about it as rather then dim I would just hold the turn signal cancel button and turn them off. Easier then hitting the wonder wheel over and spinning it to the desired dimness.
Where it comes into play is you can set how the channel responds in the ezCAN software such as day time run 50% light and at night run 100% and any numbers in between you may want. That is a nice feature I would like to use but do not have to.
The term to use is PWM - Pulse Width Modulation. This could be AC or DC, but AC would require a DC to AC inverter and I doubt this is the case.
You should ask Hex what the output from the ezCAN is. Perhaps it is stated in literature that came with the unit.
This is another example of "systems integration" issues. We have complex items these days, not simple batteries and incandescent bulbs. Might not be possible to mix and match.
Both the lamp suppliers and Hex should talk seriously to the buyer regarding about compatibility.
The Coldwater folks told me they had customers burn out units using a totally unknown dimmer unit bought on eBay and as a result only warranty a system with their lamps and dimmers. Makes sense to me.
Buyer (and amateur Systems Engineers) Beware!
