With the speed sensor correctly located run the speed sensor wire harness onto its mounting and attach points.
With the sensor in place, the proper routing and slack will fall into place. You will be able to tell that the routing is being done correctly as you install.
Working from the speed sensor to the front of the bike, insert the speed sensor harness into the reataining clip at the 7 o'clock position.
Ensure it is fully inserted as shown before proceeding.
