K75S Tach reading funny
36532
After a short stop of about 10 mins my tach started reading low, I was near the end of my 240 mile trip. Usually at 60 mph the tach will read around 4300 rpm. Well after this stop 60 was about 3400 rpm. It did this for about 15 miles and the went to normal after a really slow sharp turn. What do I need to check to cure this or no cure for it at all. thanks
Both of the wonky tach issues that I've seen in person were because of poor grounding. Double check that your ground cable looks good both at the battery and transmission end. Is this the absolute fix? Probably not, but it's a very simple place to start.
If the problem was ONLY the tach reading incorrectly, and not the engine misfiring, the odds are a bad connection (loose or corroded) to the tach. This includes the positive signal or the ground.
The instrument cluster (along with several other things) is grounded to the left side of the center frame rail underneath the fuel tank. There is a bolt that bolts to a flange under that frame rail. There are several brown (ground) wires attached there.
Another possible poor connection could be the plug or plugs (depending on year) on the back of the cluster. On an S, this requires removing the windscreen, front turn signals, headlight and headlight panel, at the least before you can get to the connector.
Another possibility is poor connection or corrosion on the pins INSIDE the cluster. The tach plugs into a circuit board inside the cluster. Water has been known to cause moisture, condensation and corrosion inside these clusters.
Another possibility is a circuit board that is going bad inside the cluster. I just got done fixing a speedo that was reading double the proper speed. The fix was a new tach/speedo drive board.
:dance:dance:dance
