DJW
In addition to the u-joint issue (see other thread), my final drive has been puking oil
. There is glop all over the face (toward the wheel), and when I pulled the boot from between the final drive and the arm, oil came out. So, it would appear that both oil seals, well, aren't.
Is there another explanation besides this most obvious one? If not, does replacing these seals come short of a complete rebuild of the final drive, as far as complexity goes. Also, according to Max's fiche, the seal leading toward the drive shaft is not available. What are my options?
Thanks.
Thanks.
