H
Hooter
Greeting fellow MOA members. I need a bit of tech help.
I have an 88 K100LT, 55,000 miles in good condition. Here is the problem.
Sudden low RPM power and performance. I crossed a warning strip on a highway and the trouble started. The big has poor power and misses below 2000 rpm. I have checked plug wires, plugs, fuel filter, pump, air filter, etc. Nothing out of sorts. Above 2000 RPM bike runs with no problems, good mileage, power, and temperature is normal.
The problem reminds me of the older cars with a bad vacuum advance for the spark timing. I have checked and cleaned the FI computer connection but not the iginition module.
I do have an open vacuum port on the bike and I don't know what if anything is connected to it or it it left open to air or blocked off. Looking at the left side of the bike, under the fuel rail there is the idle adjustments and the vent hose that is covered by a spring i believe that comes from the crank case. To the left of this hose is a locking adjustment screw and this open port. It looks like a hose should be on this port. It is about an 1/8 of inch in diameter and is open to air. There is a vacuum at this port. What goes on this port? I think something was knocked loose when I crossed this warning strip.
Any help on this would be appreciated.
Thanks in advance.
Hooter in Tennesse
Thanks in advance.
Hooter in Tennesse
