roger 04 rt
First, let me briefly introduce myself. After taking a couple decades off from riding and maintaining Kawasaki (Enduro) Honda (Street) and Yamaha (Dirt) bikes, I bought a very well cared-for 28,000 mile 2004 R1150RT from a dealer in New England a few months ago. What a terrific motorcycle! I understand everyone's enthusiasm.
I've been reading this forum since August and picking up really good stuff on the care and maintenance of these motorcycles. After riding a couple hundred miles from the dealer to Cape Cod the bike developed a "drip" from one of the four vent/drain hoses near the right footpeg. The insight gained reading this forum helped me quickly figure out that the internal hoses from the filler area of the gas tank to the filter/fuel pump assembly were leaking. So first, a big THANK YOU to this forum.
Since taking delivery I've been slowly going over the bike, and have addressed or serviced: oil, oil filter, air filter, fuel filter and internal hoses, transmission fluid, brake fluid flush, spark plugs (Autolite, including grinding down an 11/16 socket for the lower plug), valve adjustment, idle speed, throttle body sync and several cosmetic items.
Some parts have been removed which I will post in the Flea Market: Ilium Passenger Sportboards (solo riding), Shift Extension (large feet) and Bar Back risers (long arms). And some parts added: Tall/Comfort seat (6' 3"), BoosterPlug (took rough edges off throttle response), and Kisan Signal Minder (running lights, brake flasher).
With that stuff done, I'm hoping to get some help with a few questions:
1. The dealer replaced the alternator belt and after 1,000 miles it's squeaking for a moment after start. I'm guessing the tension wasn't set correctly. I'll have to check which belt it has (Poly V or Elast). How important is it to use the special BMW tools when adjusting tension?
2. When will the clutch spline need to be lubricated and how would I know? It looks like a pretty big job.
3. I think there is too much play in the throttle cable at rest. How often does this need to be adjusted?
4. Should I wait for the plastic fuel quick releases to leak or is this a time-bomb needing attention?
5. It seems like the gas cap doesn't seal to the filler neck. Is there an adjustment?
6. When the internal tank lines were leaking, most of the fuel dripped from the neck tube but about a quarter cup or so came out the canister vent. What are the chances that the canister was damaged?
Thanks again and glad to have joined.
Roger
Roger
