High resistance in the light bulb circuit could (and should) trigger the general warning light from iABS unit, but I seriously doubt that it would put the system (front or rear) in residual mode.
My main complaint about iABS is that it makes you think about brakes, which is really not a good thing to do while riding.
Keep us updated.
I agree with both sentiments you expressed. I understand how any rear light, original 1157 dual filament bulb or aftermarket LED, will trip the lower BRAKE WARNING light. I have experienced that phenomenon with both types of rear lights in my '04 1150 GS, and in both instances the lights were fully functional. One of the filaments blew in the 1157 bulb a couple of weeks after the warning light was tripped by the increased resistance of the failing filament, but the LED never demonstrated a malfunction. I do not, however, understand how an aftermarket LED that had or developed abnormal resistance can illuminate the ABS (upper triangle) warning light and record a specific failure as measured by the GS911. I have found both low pressure in circuits and defective rear ABS motor faults, but always listed as No Longer Present. The fact I have gone 150 miles with the original bulb (sans LED) and not seen any warning lights gives me the slimmest glimmer of hope, but as stated I will not exhale until at least 500 miles and then only partially exhale. Perhaps after several thousand miles I'll breath normally again.
Your comment regarding the distraction is absolutely correct. I've ridden several hundred thousand miles over nearly 5 decades and, although admittedly lucky in the formative years, have avoided any serious accidents because of a practiced focus on what's going on around me. Lately, however, I find myself frequently looking to see when the warning lights illuminate, this despite the fact that my brakes have never failed to function normally. Last statement excludes certainty the ABS is functional when upper ABS light is flashing.
I have asked Advrider.com poster, who lives in Norway, if he is aware specifically of an LED brake/running light triggering an ABS failure warning light and not just the lower brake failure light.
