guitardad
Original Oilhead
... should the starter draw on my '94 R1100RS?
OK, some background. I've been getting intermittent ABS faults - the alternate flashing lights that means low voltage at startup. Basically, I have to make sure EVERYTHING is turned off when I start the bike - driving lights, heated grips, even my XM Radio! Battery is only 6 months old. Now, as the temps drop into the 50's, the fault is starting to come back. So I'm starting to suspect the starter is the real issue - it's drawing too much current. I borrowed a clamp-on current meter from work, so I can measure what it takes to spin the starter up. But what's a good number, and what's too much?
