RSSSSSSS
Ok, I've messed with my throttle body butterflies (you know those marked screws on the bottom of the bodies that you aren't supposed to touch) on my 94 R1100rs. Now I'm trying to get them back to stock or close. I'm experiencing some hard starting issues that only happen when the bikes cold. Once it's started and warmed up it always restarts easily. Allow it to cool down and the hard starting resumes. The plugs are new, new plug cables, good coil (tested) good hall sensor, valve adjustment good. Throttle sync. done. The timing seems to be fine, Fuel filter changed, plenty of fuel pressure at injectors, compression is 145psi on both sides. zero=zero done on TPS. Bike has 33,000 miles on it. Also fitted with an older techclusion so the O2 sensor is disconnected.
The only info I can find online is that the butterfly angle at closed should be 10 degrees. Problem is I don't know how to measure that to adjust them. I set them as follows: Loosened all cables, adjusted both throttle bodies so that the bike would idle at 1000 rpm (with tps @ lowest setting and BBS all the way in, techclusion disconnected). At this point the 1000 rpm was synched using a manometer for just the throttle bodies. Then I used the BBS to raise the idle to around 1100 (still synched) The next step I set all the cables at idle and at just off idle (again synched). Still hard starting when cold. I have to use fast idle switch and crank open the throttle for ten or so operations of the starter to get it to finally catch. Any ideas on what else to try? Sorry for the length of this but wanted to give all the background I could think of.
Larry
Larry
