How do I fix a stupid mistake?: 2004 R1150RT Clutch balance
banzaibob
The slave cylinder failed and puked fluid all over the friction disc. It was ruined. Removed the entire clutch pack from the bike. I forgot if I indexed the position of the components but it doesn't matter anyway because the shop that rebuilt the friction disc ALSO ran the pressure plate, spring and housing cover through a shot blasting machine to clean it up. Therefore any marks I may have made are now gone. My concern of course is that this entire thing will be WAY out of balance.
How in the heck do I fix this? Is there anyway to determine overall balance of the entire clutch pack/flywheel once the index marks have been lost?
New parts I have bought had no marks on them.
Done a few with no balance issues including my own twice.
Drill a hole in the transmission as below.
A fluid leak or trans oil leak will not contaminate the clutch again.
Check with that clutch shop to see if they can balance the individual components or the complete assembly without the spring and disk if you give them the flywheel, support plate and hardware. If they can do the assembly, try different orientations to find the best combination. If they can do individual components, just have them mark the heavy side without acutally balancing. The R1150 clutch cover and pressure plate I just got from Max had the heavy sides marked.
