D
Daver90s
I have a Quest and it seems to allergic to my R100gspd - It will find satellites and navigate just fine as long as I'm either stopped or at a constant speed on the e-way. If I change speed, it loses signal. I tried it in my truck and it works just fine. I have a hypothesis: Maybe my ignition coil is interfering with the unit somehow. Maybe sending out an EM pulse that block the signal from the satellites. Has anyone experienced this? Is there a fix? Either with this model or another Garmin? Also, sometimes it resets itself by turning off and then back on. I tried running it on battery power only but the problem is still there.
weird.
weird.
