I'm the second owner of a pristine 2008 R1200R I bought it in May with 5200 miles, it now has 8100 miles, when I apply the brakes I get a surging effect and over the last month it is getting worse. I took the bike to Wolfe BMW in London Ontario for a couple of recalls and asked if they could check out the surging effect I suspected it could mean that their is air in the breaking system however it turns out that the front rotors are warped causing the surging effect when I apply the brakes.
The service manager suggested the probable cause could be that the previous owner may have trailered the bike and on tying it down may have damaged the rotors, however he suggested the most likely cause was when I had a new set of tires mounted and the bike shop installed was not careful and bent the rotors in the tire changing machine.
Does any of this sound familiar?
The tough part is to replace the rotors it will cost me $1100.00 and only BMW Germany has stock.
I'm surprised that not one but both rotors are warped?
Any suggestions?
Thanks Cliff
Any suggestions?
Thanks Cliff
