AnnapolisAirhead
--Tony
I had an odd thing happen. I have just recently gotten my bike on the road from an 8 year hiatus. Yesterday a couple stopped me as I was loading up my groceries and said "Nice bike". My first comment on the bike...well, he knows bikes, especially airheads. So we chatted as he and his gal looked it over.
I told him I probably only have a couple hundred miles on it...he mentioned changing the final drive, shaft and gear box oil. He was pointing out the drain and fill plugs and we discovered that the fill plug and washer was gone. MIA. Took a walk-about....and I know it was there, I'd taken the rear wheel off several times--not happy with the spline lube, new tire were mounted without tubes on snowflakes, etc.
Great, I am (fortunately) only 5 miles from home, clear day. So I cautiously headed directly home. Great, now it's Saturday night.So much for the Sunday morning breakfast run. But I am a sailor and try to plan for any failure--spares, tools, etc. I just wasn't prepared for this.
Here's my emergency plug fix: a rubber stopper plug, just like the ones used in dinghies.
I found several sizes at my local TruValue hardware store, found the one that fits, smeared a bit of lube on it, twisted the lever and flipped it back to lock in place. As the final drive, shaft and trans were draining, I took the plug to a vise, and cut off a little bit of the threaded piece that sticks down close to the innards of the final drive--even though I measured it would not touch any moving parts.
I put the remaining plugs in a ziplock and in the tool tray, just in case. I'll pick a proper part up tomorrow, but this got me through and as long as its not a part of the bike that generates excessive heat or any part of it gets in the way of moving parts--it should help someone out of a tough spot.
