2
2old2rockNroll
I've spent the week getting the K-bike ready for it's garage nap...( I give it up at 20 degrees) and there are a couple of things that I want to get accomplished over the winter months to get ready for the New Orleans run in April!
Over the last month or so The bike ('85 K100rs, 37K mileage) has been developing a bad idle. A noticeable stumble on the first 1/4 of the throttle range and a tendency to die while idling at a long traffic signal. Once off idle and past the stumble the engine responds well and the bike runs strong...but recently I have noticed the motor seems 'loose' ... no other way to put it, not a rattle but a general feeling of ...well...looseness. Yeah I know, pretty vague.
The bike has strong compression across all four and the electrics are up to spec on output. I rebuilt the airbox plastic this summer, so the airtrain is tight. Plugs always look good...nice and tan and dry.
There is an exhaust leak as well as a dented pipe which will get fixed this winter, I don't know if this is could be a factor or not. I am also going to do a valve adjustment. One thing I have noticed: idle speed seems to drop sometimes while sitting...it usually stays right at 1Krpm but will drop down to 800 or so ... sometimes it 'searches' low and high...this is all new behavior, last summer it was rock steady at 1000 rpm.
Is there anything else I should be looking at? Maybe hidden hoses I missed? Sensors?
I am pretty anal about clean gas and run a few ounces of seafoam through every month, so I'm thinking it is not crap in the system, I also pulled the tank last summer and cleaned it thoroughly and like I said, this problem is only at idle.
If you guys would be so good as to lend me your expertise, what I would like is a systematic breakdown of how to best ferret out this low end problem. I realize a certain amount of ragged bottom end is inherent in this motor, but in my case it getting past being an annoyance and into limiting safe use of the bike. I don't want to haul her into the local BMW dealer: A, I can't afford it and B, If I wrench it then I will know what it needs the next time.
Thanks in advance,
John B
Thanks in advance,
John B
