Checked with my dealer - the recall was for the fuel pump, not the FPC. I sure hope it's just that switch and not something more mysterious. Bypass wire is on it's way!
DP
Greetings - 2007 R1200RT, 59,000 miles. Last week as I was approaching a stop sign and almost stopped, the engine suddenly died, thought it was just a fluke, but did it again yesterday. Restarts immediately. No codes on the dash. Bike runs great, rev's fast, and had never done this before. Any ideas? Thanks all.
DP
My 2007 RT has done exactly the same thing, perhaps 3-5 times over the course of 2-3 years. It happens mostly when reducing speed. It has happened a few times after pulling the clutch and coasting to a stop light. It comes back to life after hitting the starter. I rode it from CA to AZ and back last year and the problem never showed up. Go figure.
the left headlight burned out! Thorough job of scrapping my hands replacing that thing. Need E.T. phone home like fingers.
DP
Better lucky than skilled sometimes.
Just ordered up the bypass cable from BurnsMoto. Thank you Omega Man for the tip. What did we ever do with-out all this help, back in the old days??
DP
It usually happened when my wife was on the bike and that alone caused me much grief hearing her go nuts over it.
DP
One of the best lists of suggestions for dealing with this sort of bike problem, or almost any bike problem I've seen. In particular the last item. 'Nuff said.
- Don't assume it's the fault of BMW exclusively. Kicking dirt and bad-mouthing dealers and brands isn't going to change anything unless you can prove gross negligence. The experience may be yours alone and how you choose to deal with it.
- The dealer has to be able to reproduce it or they'll take shots in the dark.
- Use a logical approach to solving it. Frustration isn't a helpful tool.
- Don't assume someone else's issue on a forum is directly related to your issue.
- Develop troubleshooting techniques (fuel, air ignition, etc.)
- Don't assume the major components first, sometimes the simple small stuff is the problem.
- Electrical Parts that "look okay" can not be okay. Use a multimeter.
- If you don't have the technical skill or reach your limits, get help.
- It's really helpful to have people that ride the same bike you ride or the same platform. You share information.
- Forums can be a great or terrible source of information. Use discretion.
Yep, same symptoms I have, hopefully had. I went ahead and bought/installed a new Fuel Pump Controller, part #16-14-8-523-262, the same day my BurnsMoto cable arrived. When I started the bike with the new controller, the left headlight burned out! Thorough job of scrapping my hands replacing that thing. Need E.T. phone home like fingers.
DP
FOLLOW UP: After installing the new Fuel Pump Controller the engine died one time. Again no codes. I shared my frustration with service guy Jim at Moto Italia, formerly Beemers and More. He suggested I try some BG-44K fuel treatment; put in half a can, fill the tank, and ring it's neck! (ride it like I stole it) Bounced off the rev limiter several times. Filled the tank again, dumped in the other half of the treatment, and rode it like I stole it. About 400 miles total. THE ENGINE HAS NEVER RUN BETTER!! For anyone having these symptoms, try this, it might be all it takes.
DP
