trevorwatson
Has anyone installed Dynatek Dyna III Electronic Ignition Systems D35-1 on their bike. I am thinking of installing it on my 1975 R90/6 but would like to hear some input and or Thoughts from someone who has it. Thanks.
by moving one magnet just a bit.
...and by adjusting one sensor or the other during set up both coils can be made to fire together - and, the double dot in the timing window will go away.Just for clarification...there's only one magnet, which is in the donut that is fastened to the central shaft of the advance unit. What you're adjusting are the pick-up coils. It's basically a Hall effect sensor set up. When the magnet/steel piece in the donut comes into vicinity of one sensor, it creates an electrical current in the sensor which is used to operate the system.
I've used one or two on my bikes, but only because they came that way. I prefer the Boyer ignition. I've used Boyer ignitions on several bikes since 1976 with no problems.
What I like about the Boyer is that it is totally electronic, with no moving parts! It is truely a set and forget unit, unlike the Dyna which uses the original advance unit. The springs wear out, you have to go through the hassle of adjusting one of the pick-ups, and you have to torque the set screws just right! Too tight and the lobe sleeve will bind. Too loose and the screws can back out, leaving you with no timing at all.
Just my opinion.
points with an amplifier
Does the amplifier actually increase the strength of the spark, just cut the voltage going through the points or both?
What advantages do you see over just the conventional points set up?
I'm no electrical expert, but I'm having trouble seeing how a points amplifier will make a stronger spark. It certainly does help extend the life of the points, by reducing the voltage across them. But the points are nothing more than a switch which allows current to run to the coils to saturate them. When the points open, the fields collapse and the huge voltage is sent to the plugs. I don't see where the coils care what's coming to them, either through the amplifier or not. How does the amplifier modify the voltage to the coils? Does it somehow let the voltage get their faster? Does it allow the saturation to last longer? I don't see that these sorts of things are happening, which would likely deepen the saturation, and thus increase the spark voltage. Just scratching my head...hmmm...
If the amplifier uses the points only as a signal source, much like a Hall Sensor, is it possible that dwell time is more consistent and precise? If so, would this improve the density of the spark delivered?
