Stuff2C said:IÔÇÖve been making my own for years. Just take your garage door opener apart and find the push switch on the circuit board and solder the switch closed. Remove the battery and solder a red wire on the positive side and a black on the negative side (color is not that importantjust get polarity right). Then wire the positive to the high beam on your headlight and ground the other one. Pull up to the door and flash your high beam. Never look for that lost in the gear remote again. By the way mine uses a 9v battery with no ill affects on the unit for many many years of use. I have one on every one of my bikes.
I have the BigDO wired to my four ways, bike powered no worries. It's velcroed to the inside of the front fairing.MCMXCIVRS said:I use a small key chain sized remote that I keep on my bikes key ring.
phil said:Wow I am impressed. I just hit the horn or yell to the wife to open the garage door. You guys are crafty devils.
Phil from Saintpete Fl.
P.S. Usually come home late at night. At that time she is usually naked. It was quite a show for my friends.They seem to come over alot more lately.
RTRandy said:This is the part I'm not getting: The circuit on the bike is 12 volt and the circuit on the opener is 9 volt. 12volts going to a 9 volt opener spells fried opener if you ask me. Yes? No?
BradfordBenn said:Not always. There are things called voltage regulators that can take the voltage down. Check out radio shack for the part.
pudgypaintguy said:This raises a good question though, as this would mean that everytime you ride with main beam there would be a charge to the remote. Stuff2C have you burned out any remotes in the past?..lol
