Center stand hang up
The c stand I have is not stock. Some kind of RTP abortion
Thanks... I see the center stand lube mod you are showing but my stand has a bit more to it.
I had the spring off,and the bolts out where the sleeves are an another larger bolt but the stand didn't budge.
Donno.
Remove the springs3,12,13
Remove 7,9,10,2 on each side
CS will drop down.
Center stand
GS Addict-
Okay, i see now that the piece that the screw goes into has a #10 hex.
So I got the stand off just as you said .
Need new o rings,and I think I will add a lube hole for the future .
THANKS SO MUCH for all your time and help.
John Campbell
USA
GS Addict-
John Campbell
USA
You are most welcome John.
The O rings can be sourced at any bearing house or industrial supply. Just take a sample in with you.
