m_stock10506
Well-known member
My 2001 R1100RT is very high mileage. The motor died when pulling out from a gas station today and I noticed that the RID went blank except for the clock, just like the ignition was turned off.
Got home. Up on the centerstand, side stand up, I turned on the ignition and moved the bars left and right. When the bars are moved left, maybe half-way between straight and full lock, everything shuts off. RID and all dash lights go off just as though I moved the ignition key to off. I thought that the tight cable ties issue was an 1150 build issue, but sure looks like that's what I have.
With these symptoms, which wire is likely breaking and where should I be looking? All of the sheathing covering the wire bundles is still intact now, so I'm going to have to start cutting cable ties and peeling away the outer sheath.
Thanks.
Thanks.
