Putting the front end back together and am having with the fork brace. The fork tubes are installed and torqued at the lower clamp. Top nuts are hand tight. I can put the axle in and it spins freely. I've read that the axle is suppose to move freely.
The fork brace had to be bent together using a pipe clamp as the holes did not match up with the studs. They do now and the brace goes on with out force. I can torque the two nuts on right (facing the front of the bike) and the axle still spins freely and moves back and forth. I can tighten the nuts on the left by hand and still get movement from the axle. Once I start to torque the left side, it seizes up any movement on the axle. The issue follows the same side of the brace if I install it upside down. I noticed a wedge of space on the left (shown in pic) side and saw that once that starts closing up, the axle seizes. I made some shims and tried to fill the space so the but it doesnt help.
Am now looking for assistance on this issue. -Adam
