Bent Font Wheel 2012 1200 GS
Davesbmw
Member
I hit a very large pot hole while riding and bent the front wheel on the GS.
Have it down at Woody's Wheel Works for repair.
After reading the replacement procedures for the two front rotors the BMW shop manual recommends replacing the 10 bolt that secure them to the hub.
Is this really required or can you clean up the old bolts and add a loctite to them and reuse them ?
These are not small bolts and the torque is only 19 nm
Dave
you're talking about the caliper mounting bolts, right? not 100% sure if you can reuse or not... but my R11S has had its wheel and calipers off dozens of time, still using the original bolts, always torqued to spec (29.5 lb ft), never used loctite, never had the wheel wander off on its own.
btw- we're nearly neighbors. i live in Loveland, but work in Windsor. feel free ti PM me about going for a ride some time, if'fn you'd like.
Dave
were it my GS, i would clean, Loctite 243 the bolts and reuse them.....
best to wire brush the threads on the bolts and chase the internal threads of the hub with a tap...then clean with brake cleaner...
wyman
I might not have made my self clear. yes the mounting bolts for the disk 10 in total.
the round things the calipers clamp on to bring you to a stop. The disk or rotors not the calipers.
But yes let's go for a ride
Dave
I would do something similar... but after the clean step I'd make sure the screws fit the holes and could be threaded without using tools. If not the screws are possibly stretched in which case new screws would be appropriate.
FWIW I was able to reuse the screws when changing the rear rotor on my '05 GS.
i would seriously doubt that 19nm (14ft/lbs) would stretch the rotor bolts
But who knows what ancillary damage a hit to the wheel enough to send it out for repair will do. It only takes a minute to check.
It's more of safety and liability issue than anything else. Not worth taking the chance. Have wrenched on other makes and models including HD and the books say the same thing: "discard and replace".
