beemerphile
(I wonder how long a bike will run on a Lithium battery pack...)
The instructions specifically warn against it. If the battery is internally open vs. discharged or weak, then as Paul stated, it will not solve the problem.
Sometimes, as Randy Newman says, "you just got to roll with the punches".
On a trip long ago I had the inevitable rotor failure and bought a cheap car battery at Sears and strapped it to the luggage rack and came home "total loss" without running the headlight. That worked better before EFI and fuel pumps and so forth. A bud and I once stopped every 100 miles and swapped batteries when his charging system quit. After the second adventure, I started carrying full charging system spares in the smuggler's hidey place inside the seat cowl. Of course, the parts were never needed.
Otherwise, you wait it out in situ or wave your Visa card at the UHaul guy and haul its lame arse home.
