The bike's in a storage unit so I'll have to check the battery manufacturer. Battery is held in place with two threaded posts on either end and a metal bar that goes across the top of the battery and is secured to the posts. Some modern batteries fit in the bike but are too tall for the metal plate to be screwed in place.An OEM battery too tall? Seems unusual to me. What batteries have you been running the past? Why not just continue using those?
Actually I do have to flip the hold down bar over to get it to work.... and was thinking of getting just a flat bar to use. I was hoping someone had run across a battery that fits.I have more or less the same set up in my /7. I've been running a wet-cell battery in it from BMW for years. Mareg I think is the name. There are aftermarket batteries which are the same dimensions of it. It's a tight fit, but I've just learned to live with it every 5-6 years.
I wonder if the metal bar in your case can be flipped upside to down to work better? Or can you fashion a bar of your own that has an offset built into it to fit. Certainly if you find other batteries that are less than the original size, you will need to add spacers of wood or hard plastic to ensure that the battery stays secure. Snowbum has an article about batteries on his website:
BMW motorcycle batteries, chargers, initialization, flooded, lithium, LiFePO4, lead-acid, de-sulfating
New Battery, LiFePO4,lithium and AGM/VRLA batteries, BMW, motorcycle, motorcycles, filling, charging,load,test,load-test,anti-sulfatingbmwmotorcycletech.info
In the middle of the page he has a section called "What to Purchase". Might be a good place to start.
Thanks, good suggestion. Many BMW's are listed on the application list but for some reason the 83 R100RS is not listed....$75 and free shipping to your door:
YTX30L-BS High Performance - Maintenance Free - Sealed AGM Motorcycle Battery | eBay
High Performance Maintenance Free Power Sports and SLA Batteries. Go further and do more with its enhanced performance. The newest technology for Power Sport Batteries:Bluetooth® Phone Connectivity!www.ebay.com
150,000+ transactions and 99.5% satisfaction. Chrome battery is my go-to place for bike batteries.
Verify it fits your bike before ordering.
FYI, Those subframe bolts insert from the inside, nut on the outside. Also keeps the bolt end from wearing a hole in your tool tray.I've been using these in my bikes since 2012. They're a tiny bit taller than the stock battery but it works if you flip the top clip over so it's concave from the top. And this pic demonstrates the really really really cool feature of them:
Yes, just a bit narrower than stock so it fits from above. No need to disassemble the airbox for install/removal. At least after the first time. In the pic I've backed out the right subframe bolt for clearance. Some bikes need that, some don't. AGM from Interstate.
